I need some instruction on how to raise the needle on a banshee
I need to raise the needle in the carbs on my banshee, but I really dont know how, does anyone have step by step instruction, like how to remove the T.O.R.S. and throtle cable and stuff..thanks
Chris
Chris
I don't have step by step instructions but I'll do my best.
Remove the following: radiator cover, front plastics, gas tank
now loosen the screw that holds the caps lock(gold colored piece), and then unscrew the caps and slide then up, now with a small phillips screw driver or even a small flat screw driver go inbetween the springs into the slide and remove the two screws down in there and slige the spring out. You will now be able to remove the neeedle and adjust the clip. When you put in back be sure and place the open hole(breather) on the slide to line up with the one on the spring retainer and then reverse the above steps. BTW do one at a time and be sure the slant part of the slide goes towards the air filter.
