can I run this sproket w/ this chain?
You will probably need to remove 1 link from the chain. But this is not recommended. You should not use a new sprocket with an old chain. Your new sprocket will look just like your old 14 tooth in about 10 hours of riding. Your chain is stretched. It is recommended to replace your front and rear sprockets and chain as a set all at the same time. You can do this for under $100. (Or over $300 if you go with Sidewinder brand chain and sprockets) Good Luck!
RR1
RR1
mrtidy
02-03-2016 05:00 PM
