raptor exhast?
Old Feb 5, 2004 | 12:38 AM
cdrracingguy's Avatar
Default raptor exhast?
I am going to get a pipe and header for my raptor but can't decide.
I am between the LRD full pipe, LTE duel exhaust kit full pipe or curtis sparks.
I think they are all pretty close but if any one has them that could help me out that would be awsome.
Old Feb 5, 2004 | 12:50 AM
BigScary's Avatar
SPARKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
You won't be disappointed!
Old Feb 5, 2004 | 12:58 AM
DragRaptor727's Avatar
yeah go with sparks, great pipe.
Old Feb 5, 2004 | 01:07 AM
has any one heard how the LTE duel exhaust preforms?
Old Feb 5, 2004 | 01:25 AM
Outlawlawndragster's Avatar
Yes it Luney Tunes Exhaust I have heard they sound pretty nice . But havent heard any on performance
Old Feb 5, 2004 | 10:45 AM
Freez's Avatar
If you want something that looks trick, then get yourself the LTE exhaust system. I don't want to start an argument again about this, but the LTE is heavier and since the pipes are not of equal length, they cannot produce the same sort of HP as good single pipe system. Pipe length and diameter make a big difference in performance, and the 1st thing a good exhaust tuner will tell you is to get the pipe lengths the same.
If you need performance, then go with sparks.
I hope to have my sparks in about two weeks. I will try and dyno the pipe and compare it to a DMC, using the same bike. I am doing it to prove to myself what the differences are. A DMC pipe is very similar to a LTE, both having two pipes all the way to the back, and two silencers. (DMC is one silencer, but it is split inside so each pipe has its own outlet, making it the same sort of setup as the LTE)
Old Feb 5, 2004 | 10:51 AM
BlackRaptor's Avatar
Sparks!
But I am starting to like the Alba pipe. It sounds awesome.
Old Feb 5, 2004 | 02:21 PM
Yamaha660R's Avatar
Sparks out of the three...but don't forget the performance of the Alba Stage 3 Kit either. It definetly wouldn't disappoint you.
Old Feb 5, 2004 | 03:00 PM
bad350twin's Avatar
i would go with sparks, ct, or mbrp!!!!
Old Feb 5, 2004 | 03:30 PM
maddog56's Avatar
sparks is great, but very loud. ct makes great hp, and can be adjusted with discs. alba is loud, but has discs too. alien pipes are supposedly very loud as well. yoshi is quieter with inserts, and makes good power too. it really depends on what you plan to do with the bike. some pipes can rob hp if not coupled with other engine mods.
