Blaster oil inject shut off?
Old Feb 5, 2004 | 09:05 PM
Trinity748's Avatar
Default Blaster oil inject shut off?
Hey my brother just got a blaster and i saw some people saying they had oil shut off's on their's....whats up with that? why would you want to do that? Is it running to heavy on the oil?
THX
Old Feb 6, 2004 | 03:44 AM
dmaster79's Avatar
Unless I'm mistaken...thats an oil block off, not an oil shutoff they are referring to. An oil blockoff would be if you were to mix 2 stroke oil with the gas, for dependablity issues and to make sure your piston is well oiled. Some people claim the factory injector may fail causing big problems. Either way, your 2 stroke needs its oil or its in trouble.
Old Feb 6, 2004 | 08:34 AM
Shav0's Avatar
now that were on the topic, does anyone know what ratio to mix the oil in a blaster if the injector has been removed.
Is it stll 32:1?
Old Feb 6, 2004 | 08:36 AM
yamahayfz450's Avatar
yes you just take the pump out remove the oil tank and off you go it's realy easy and saves the pump packing up on you and messing up your engine
Old Feb 6, 2004 | 08:40 AM
Shav0's Avatar
if it is so easy, then what all is involved with the kit? do u even need a kit to do it ?
Old Feb 9, 2004 | 04:32 AM
no you could do it with some gasket paper and a little metal plate easy
Old Feb 9, 2004 | 05:32 PM
wanaply21's Avatar
besides taking of weight on the bike would shutting it off really make it rune better cuz when u mix you dont get the precise amount of oil to gas but with the premix it mixes exactley if nothing is clogging it
Old Feb 9, 2004 | 05:43 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
shavo- The ratio depends on what u r running. EX: yamalube- 32:1, golden spectro- 50:1
wanaply21- It does not have to be mixed precise, as long as there is enough to lubricate the piston and not to much, it will last just as long if not longer.
trinity748- The blockoff is a great idea, the automatic injection tends to fail a lot and scars the cylinder pretty badly. This just happened to my friend less than a month ago.
BTW, It is only 30 bucks for the kit in the rocky mountain catalog.
Hope I helped you guys,
-Brandon
Old Feb 11, 2004 | 01:01 PM
Spoony's Avatar
I took it off mine. It took about 30 minutes. Tell him to make sure that the kick starter is in right. I run 32:1 with red line 2-stroke race oil. Red line oil is a pure synthetic. It burns super clean. Just a month ago my top end blew out. So, I made sure I stopped any possible problems.
Old Feb 11, 2004 | 03:21 PM
raptorblasterracer's Avatar
Is it stll 32:1?
yup i think so
and i used this kit on my racer VERY EASY INSTALL
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
