Blaster - top end rebuild frequency
Old Feb 6, 2004 | 01:10 PM
wannabe1's Avatar
Default Blaster - top end rebuild frequency
Blaster guys, I am debating the 2 stoke vs. 4 stroke issue and would like info on the following topic:
Assuming I ride a blaster recreationally (not racing) 2-4 hours a weekend and keep the air filter clean and good quality injection oil in the tank, how many hours would I typically get before needing to open the top-end and changing rings, and eventually the piston? Does anyone ride up to 200 hours w/o a rebuild?
Old Feb 6, 2004 | 01:13 PM
Shav0's Avatar
My blaster is a 2000. I ride it every day and ride it hard. Sence i got it i have only rebuilt the top end ONCE and it didnt even need to be done. I was just bored and had the parts so i did it. The blaster can go along time with the same tip end expecially if you are just puttin around on it. I think my bike was wayyyyyyyyyyyyyyyyyyyyyyyyyyyyyy past 200 hours after i rebuilt it and it still worked fine.
Old Feb 6, 2004 | 01:24 PM
ShadyRascal's Avatar
What he said. It's really not an issue, unless you're racing the nuts out of it constantly. I put rings in our '98 last year, the first time it had been apart. The do go a long time between needing top ends.
If you have a Banshee hill shooter that gets revved to the moon all the time, well maybe that's a different story.
Old Feb 6, 2004 | 04:27 PM
wannabe1's Avatar
Thanks, and that sounds good. What I don't understand is that if you ask the same question under the same conditions but about a yz250 (mx bike), those guys will tell you 40-45 hrs between rebuilds. Is that because the blaster motor is old tech and the yz250 has tighter more demanding tolerances? or does it have to do with the injection vs. premix?
Old Feb 6, 2004 | 04:46 PM
That YZ 250 is making around 40 horsepower, while the Blaster is about 17. The pistons and rings are made out of the same stuff, it's just a matter of the differing amount of stress each is put through.
Old Feb 6, 2004 | 07:52 PM
shlekter's Avatar
i would take the oil injector off and just run 32:1......its failed me once..........
Old Feb 6, 2004 | 10:47 PM
crispy's Avatar
I've had my blaster for 8 months, and just rebuilt it last month. It didn't really need it, but I'm a throttle jocky and am always givin it to her. all i did was re-ring, hone the cylinder and a new piston.
Old Feb 7, 2004 | 11:58 AM
wanaply21's Avatar
iv had my blaster for about a year now and ride it everday, and it sounds just as good as it did when i bought the thing so id say dont worry about it
Beeline08
Nov 11, 2016 04:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
