Raptor 350 vs Warrior
#31
Ok how about a smaller carb and cheaper rear shock. How is that better? WOW a whole extra .400 travel, but no rebound dampning. I did say the warrior was a good bike, I coose the warrior over the 400ex because of reverse. I also choose to upgrade from the warrior to a lighter, and more up to date bike. Oh well have fun arguing over it. But I think yamaha's past speaks for itself. Again, just refer to the raptor 90. Go read the reviews and compare the specs to the standard yamaha 90. they are identical.
#32
Originally posted by: warrior68man
He didnt say it would, he was pointing out the differences between how its different from a warrior...read closely before you talk.
And By the way, I think it is possible for it to beat a 400ex, Warriors can hang with 400ex's like it or not, so this thing may just be equal or better.
Originally posted by: getusummm
ok...maybe you need to go read the specs again. i am not going to argue, but i really suggest you look at the specs and hit the compare button.And somehow i dont think footpegs and brake lights will make it faster or handle better
#35
Raptor 350
Tires/Front 21x7-10
Tires/Rear 20x10-9
Tires/Front 21x7-10
Tires/Rear 20x10-9
Dimensions
2004 Raptor 350
Dry Weight 375 Lbs
Fuel Capacity 2.4 Gallons
Ground Clearance 4.5”
L x W x H 69.7”x 43.1”x 42.5”
Seat Height 32.3”
Wheelbase 47.6”
Warrior
Tires/Front- AT22 x 7-10
Tires/Rear-AT22 x 10-9
Dimensions-
Dry Weight-397 Lbs.
Fuel Capacity-2.4 Gallons
Ground Clearance-4.9”
L x W x H-72.4” x 42.5” x 42.5”
Seat Height-30.1”
Wheelbase-47.2”
Raptor still wider, even w/smaller tires. Almost 3 in length difference to. Plus bigger carbs. Very respectible mid-size ATV!
#36
2004 Raptor 350 Spec Comparison
Compare 2004 Raptor 350 specifications with another model
Engine
2004 Raptor 350
2003 Warrior
Bore x Stroke
83mm x 64.5mm
83 x 64.5mm
Carburetion
Mikuni 33mm BSR
Mikuni 36mm
Compression Ratio
9.2:1
9.2:1
Drive Train
2WD; Sealed O-Ring Chain
Ignition
DC - CDI
DC - CDI
Starting System
Electric
Electric
Transmission
6-Speed Manual Clutch w/ Reverse
Type
348cc 4-Stroke Single, Air Cooled, SOHC
348cc, 4-Stroke Single, Air Cooled, SOHC
Chassis
2004 Raptor 350
2003 Warrior
Brakes/Front
Dual Hydraulic Disc
Dual Hydraulic Disc
Brakes/Rear
Hydraulic Disc
Hydraulic Disc
Suspension/Front
Independent Double Wishbone, 7.9” w/ 5-way Preload Adjustment
Suspension/Rear
Swing Arm, 8.3”, and Threaded Preload Adjustment
Swing Arm, 7.9” w/ Rebound, and 5-way Preload Adjustment
Tires/Front
21x7-10
AT22 x 7-10
Tires/Rear
20x10-9
AT22 x 10-9
Dimensions
2004 Raptor 350
2003 Warrior
Dry Weight
375 Lbs
397 Lbs.
Fuel Capacity
2.4 Gallons
2.4 Gallons
Ground Clearance
4.5”
4.9”
L x W x H
69.7”x 43.1”x 42.5”
Seat Height
32.3”
30.1”
Wheelbase
47.6”
47.2”
Other
2004 Raptor 350
2003 Warrior
Colors
Team Yamaha Blue/White; White/Red
Team Yamaha Blue, Black/Red
Lighting
Dual 30W Krypton Multi-reflector Headlights & 21/5W Brake light
Dual 30W Multi-reflector Headlights & 21/5W Brake light
Warranty
6 Month (Limited Factory Warranty)
MSRP
$4,999* Available from April 2004
Not Available
#37
As you can see, it actually has a 3mm smaller carb, is only .600 wider, .400 longer, .400 less ground clearance, 2.1 higher seat height, and only .400 more rear travel. These are yamaha's numbers, not mine.
#39
I honestly think this makes the Raptor look bad in general. Now EVERYONE will talking about how they smoked a Raptor. Not sure what Yamaha was thinking here.[img]i/expressions/face-icon-small-confused.gif[/img]
#40
The overall length is shorter by 2.7 inches, but shows to have a .400 inch longer wheelbase. I think this is due to bumper differences on overall length. I think the wheelbase comes come from dropping the rear. It appears they did that by lowering it just a little. I can make mine shorter or longer with more or less rear shock preload. It seems I have offended some people, that wasnt my intention, but i do look at specs and know what each one means. I also remember the raptor 90, I almost bought it for my kids, until I compared the 2 yamaha 90s. Same bike, different plastic. This is basically the same thing. I am not trying to degrade the warrior. i had one and it was a fun bike. I am just saying yamaha did a poor job and dont expect it to beat a 400 in stock form. This really only applies to drag racing though. A better rider on an old 185 3 wheeler could beat a poor rider on a 660 on the track.
