KF 2004 YFZ and YZ450F Engine Parts Compatibility
Old Feb 12, 2004 | 01:52 AM
KNOWSALOT's Avatar
The Facility
Default KF 2004 YFZ and YZ450F Engine Parts Compatibility
Parts that are identical..............with the same Yamaha OEM Part Numbers
Cylinder
Head
Base Gasket
Head Gasket
Intake Camshaft
All 3 Intake Valves
Both Exhaust Valves
The Entire Counterbalancer Assembly
RockerCover and Gasket
All Valve Guides
All Int and Exh Valve Springs,Retainers,Seats, and Keepers
All 5 Valve Lifters
Cam Chain
Cam Chain Tensioner Arm
Cam Chain Guide
Cam Chain Tensioner
WaterPump Impeller
WaterPump Impeller Shaft
OilFilter Cover
OilFilter
OilStrainer
OilPump Drive Gear
OilPump
Carburetor Intake Boot [Carb to Eng]
Chain Guard Over Front Sprocket
Stock Case Saver
Outside Clutch Cover
Outside Clutch Cover Gasket
Clutch Boss
SparkPlug Cap
SparkPlug
And alot of misc. hardware suh as shims,washers,bolts,bearings,seals....etc,etc
Note: I've read in more than a couple of places about the Exhaust Cam in the YFZ being from the WR bike. Acording to Yamaha, it's neither the WR or YZ cam.
I just thought I would gather all this info and post it in one topic so that it would be easy for both you guys and myself to find at a later date if needed.
I will do the same concerning the TRX450R in the next couple of days.
Old Feb 12, 2004 | 02:28 AM
schwendi's Avatar
Damn good info knowsalot!! Thanks!!
I have one question though ... are you sure the generator covers are the same??
The YFZ has the extra gears for the electric start to accomodate while the YZ450F does not. If they are the same Id like to get the motorcycle cover since I have the kick starter
Old Feb 12, 2004 | 02:45 AM
KNOWSALOT's Avatar
The Facility
schwendi,
Yamaha calls their far outside right crankcase covers "generator covers" whether or not it actually covers the generator or the clutch.....which in the YFZs case IS the clutch.
Years of having it heard called that from Yam....I don't think twice about it.
To sum it up, no....the cover that covers the generator on the YFZ is different than the bike ofcourse with the starter boss cast in on the quad, and I don't know yet if the YZ cover will fit the quad or not.
Thanks for bringing it up. I went back and edited that piece to read "Out Side Clutch Cover"
Old Feb 12, 2004 | 02:57 PM
AlkyBurninX's Avatar
Probably the difference in the WR cam and the YZF is the decompression mechanism. I think the lift/duration is still the same. I might be wrong too.[img]i/expressions/face-icon-small-smile.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
scaldwellk
Jun 19, 2015 05:08 PM
