Drag race gearing
Old Feb 23, 2004 | 12:09 AM
04LERaptor's Avatar
Default Drag race gearing
I was just thinking- let me know if maybe I am thinking to much
I have heard (or read) about people with built up Raptors, Banshees and such having to launch in either second or third gear when racing because first gear is useless because it revs to quickly. This means they only have third, fourth and fifth to race on. Seems to me instead of dropping one tooth on the front spocket as most people do - they should add teeth to the front or drop teeth from the back sprocket to bring their first gear gearing to match what it would be like when they launch in second or third. This would allow them to use all gears to race on instead of just a couple.
What do you think?
Old Feb 23, 2004 | 12:26 AM
Yamaha660R's Avatar
A couple guys here run real high gearing to run 1-3 in the 300ft drag. I use stock gearing and run 1-3 and sometimes hit 4th at the very end. Others like to drop 1-2 teeth to launch in 2 and run 2-4 in the 300ft. All up to how you race and what kind of power you have to the ground.
Old Feb 23, 2004 | 01:35 AM
BigScary's Avatar
I use 3-4-5
you want to avoid first if you can because you have to pass through neutral to hit second..........More room for error...........
Old Feb 23, 2004 | 07:06 PM
badcompanyracing's Avatar
I start in 2nd and end in 5th, most people at the track do this too. In dirt, to gear it low enough to leave in first comfortably i would probaly end the track in second. I think you should go faster if you end in a higher gear, even if its at the same mph as lower gearing, since you are accelerating faster.
Old Feb 24, 2004 | 12:21 AM
04LERaptor's Avatar
Ahhhhhhh, not wanting to shift through neutral from first to second makes sense....over-reving would not be good. Thanks.
Old Feb 24, 2004 | 01:18 AM
RepTaR660r's Avatar
Gear it so that you will start out in 2nd.... And end the race in 4th... You shouldn't ever use 5th in my opinion....
Old Feb 24, 2004 | 01:21 AM
RoostItUp's Avatar
I go from 2 to 4, generally when I'm hillshooting I just start in 2 and hit 3 bout a quarter way up and rev that out never getting into 4.
Old Feb 24, 2004 | 09:53 AM
Bubba297's Avatar
Dont forget about tire rollout. A tall tire will help keep you from shifting down track. That's been a drag secret for a long time even with the cars. Gear it low for a hard launch and run a tall tire. The rpms will stay down at the end. Not saying you want to gear it low on a wheeler, but with the right gearing and a tire like the pro-wedge or 4-snows that will grow, you wont have to spend a lot of time shifting and can use the motor on the big end.
MikeyBoyesq
Aug 10, 2015 11:11 AM
rm6keith
Club News and Events
Jul 17, 2015 08:22 AM
HondaR24
Jul 16, 2015 10:45 AM
Robinhood
Jul 13, 2015 09:13 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
