Tips on removing Raptor axle?
Old Feb 23, 2004 | 08:36 PM
FarmStud's Avatar
Default Tips on removing Raptor axle?
I was working on putting on an extended swingarm this weekend and I ran into a little trouble getting the axle out of the carrier. To my surprise axle nuts came off real easy, but brake hub was nearly seized on the axle. I got it off after soaking it overnight in WD-40. When I tried pounding the axle out it moved about 1/4" and then it stopped. Any suggestions? I hate hitting it too hard.
Old Feb 23, 2004 | 09:30 PM
Retodd's Avatar
I just soaked mine like you did, and then took the biggest hammer i can find and wammo finally came out, problem is obvious, moisture gets inside, then the inner steel sleeve, rusts , corrodes etc.
Old Feb 23, 2004 | 10:11 PM
sixsixT's Avatar
Yep, big hammer. Put the hub on and the washer to beat against and use an old impact socket or piece of heavy pipe to hit on.
Old Feb 24, 2004 | 12:37 AM
FarmStud's Avatar
Thanks guys
toonces
Jul 28, 2015 01:58 PM
black_thunder
Jul 22, 2015 06:01 PM
cSchwartz
Jul 12, 2015 07:42 PM
cSchwartz
Jul 9, 2015 02:43 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
