Warrior carb..please help....
Old Feb 24, 2004 | 06:13 PM
dmaster79's Avatar
Default Warrior carb..please help....
I have a 2001 Warrior with stock carb on it. I want to adjust the air mixture screw cause it seems it don't idle right, the problem is I don't see it on the carb anywhere. Can anyone tell me where to look or is it even there...thanks guys...
Old Feb 24, 2004 | 06:19 PM
Eceriderjbomb's Avatar
if you mean the air mixture screw i am pretty sure that it is right inn the moddle of your float bowl.. did you take your carb off?
Old Feb 24, 2004 | 06:23 PM
2000IAWarrior's Avatar
right in the middle.. its in a round cover type thing.. in front of bowl toward motor.. try the idle scew.. its the big **** on the side
dmaster79's Avatar
No its on the bike still, you should be able to adjust the air mixture screw with the bike running right? On my Blaster it was right on the side. When it idles is idles fine for about 2min then it goes way down and kicks kinda then up a little then down and usually kills the engine then.
Old Feb 24, 2004 | 06:37 PM
Go under the bike and take the 4 screws off there gold.. make sure you dont strip them and your float bowl wil be there with the little platic fltoan.. pull the pin out of the float and the metal shocker it looks like... make sure you dont loose it then its right in the middle of your carb... Ikm pretty sure hamster showed me ask him he knows more them me
Old Feb 24, 2004 | 09:50 PM
95Wolverine's Avatar
The idle mixture screw is on the bottom side of the carb. You don't have to remove anything to adjust it. It is located on the centerline of the carb in between the float bowl and the engine cylinder. Adjusting it is a pain. A stubby (very stubby) flat head screwdriver is a possibility, but the better is a the tuning screwdriver made specifically for the application... bike catalogs typically have them.
Anyway, use a mirror and you will see the brass screw that I am referring to.
Good luck.
Old Feb 25, 2004 | 01:35 AM
dmaster79's Avatar
I found the screw, adjusted it today or so I think. What is the best way to go about this, between adjusting it and setting the throttle screw in or out?
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
