Exhaust Question
Old Feb 24, 2004 | 09:11 PM
wahwahRaptor's Avatar
Default Exhaust Question
I want to purchase the pro circuit t4, but my question is if i get the slip on, do i need to go get the bike tuned.
Old Feb 24, 2004 | 09:14 PM
Raptorboy4life's Avatar
what i learned is----> never get a slip on exhause---> i know that its cheaper and almost the same but its really not and you shouldn't get a slip on. The full system is also better for your quad because in slip ons you can have leakage and other probs.
Old Feb 24, 2004 | 09:24 PM
FarmStud's Avatar
You will need some bigger main jets and turn the mixture screws out. A jet kit will have intructions. It will take some trial and error.
Old Feb 24, 2004 | 10:23 PM
Thanks for the replies, but as I was doing further research I found out that this exhaust does not go all the way to the motor, it stops at the mid pipe. What do you guys think.
Old Feb 24, 2004 | 10:27 PM
RepTaR660r's Avatar
If you want a slip-on buy the GYTR... This should be your only choice... If your only buying a slip-on to get out of tuning then stay stock or do it right and buy a full system... Sparks would be a good choice on that... Either way, you will have to re-jet in order for your bike to perform as it should.
Old Feb 24, 2004 | 10:51 PM
ZBlaster's Avatar
everything reptar said is right... id recomend jsut waiting and getting an X-6 from curtis sparks... but whatever u end up getting u will have to rejet to perform right...
Cole Hadden
Jun 15, 2025 09:05 AM
Shainasmash
May 8, 2017 06:38 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
HondaR24
Jul 21, 2015 12:12 PM
cSchwartz
Jul 12, 2015 07:42 PM
