k&n for blaster oil or none?
Old Feb 25, 2004 | 12:08 AM
wanaply21's Avatar
Default k&n for blaster oil or none?
do u oil up a k&n filter cuz it seems weird cuz it uses a ribbed design !picking the filter up tomorrow and bikes ready for it, rear fenders are off and do i need to play with the needle jet or just the air flow screw?
Old Feb 25, 2004 | 12:44 AM
KNOWSALOT's Avatar
The Facility
If you are buying a new K&N, it will come with a small pak of oil for the first time you use it. You will want to pick up a spray can of K&N or equilevant oil as well.....you will need it later on. Do not use foam filter oil on a K&N filter. It will clog the filter.
AS for the jetting. It varies. It depends on what is done to your engine now regarding mods. Are you too rich right now? Lean? Just right?
My suggestion would be to talk to the guy you buying your filter from for suggestions. Be sure to fill him in on what is done to your quad and how it performs currently. That will be your starting point.
Old Feb 25, 2004 | 12:17 PM
wanaply21's Avatar
ok thanks i didnt want to do anything stupid befor i even install it but to adjudt the jet needle what do i have to unscrew to get 2 it? does anyone have a diagram of a blaster carb, i looked for one but could find it but i want to eventually take it apart and rebuild it just for cleansing cuz i havnt dont it and i bet it needs it
Old Feb 25, 2004 | 12:42 PM
Shav0's Avatar
On there wev-site K&N claims that no jetting is required. However It all depends on what you have done to your engin. Check out this web site on how to jet carbs and you should be alright from there.
Carb Jetting 101
Old Feb 25, 2004 | 04:25 PM
SkinnyBOi's Avatar
Great link!!! I was curios about jetting.
Thanks again,
skinnyboi
wanaply21's Avatar
yes i read that thuroghlycuz uv posted it befor, i did learn about the carbs but i dont even kno a thing about my carb i wanted a diagram of the stock 26mm carb for the blaster so i kno where every screw goes and what screw to play with to make it a lean or rich mixture
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
