would this work or do i need more?
Old Feb 26, 2004 | 06:30 PM
Raptorboy4life's Avatar
Default would this work or do i need more?
I want to get more power in my 01 rappy i was thinking if i get this High Comp Racing Piston or this Raptor Piston Kit DASA Do you guys kno anything if i get this would i need anything else? also if i do this High compression piston and cam Kit would i need anything else such as pipe or jet or anything?? Thanks -Matt-
Old Feb 26, 2004 | 08:32 PM
can anyone please help me i got to know?
Old Feb 26, 2004 | 08:41 PM
FarmStud's Avatar
Probly the first things you should do would be to get a good pipe, K&N air filter and jet kit. After that a high compression piston and cam would be good. You won't get the full potential of a piston and cam if your raptor can't breath.
Old Feb 26, 2004 | 08:58 PM
well lets say i get a high proformance pipe, jet kit, and air filter would i be able to use the kit with pistin and cam? would that make it go faster?
Old Feb 26, 2004 | 11:19 PM
maddog56's Avatar
The first kit is only for bored cylinders. You would need to bore the cylinder to 102mm for it to work. The second piston is fine for install. The third kit is also ok, but the price is pretty high, depending on who the manufacturers of the cam and piston are. You can get a good piston, cam, and gasket kit for 300-375 before the core charge. It looks like alba is overcharging quite a bit here.
A piston and cam would be great upgrades to a piped and filtered rappy. Remember though, depending on the piston you decide on, you may have to run race gas at $3 or more a gallon.
Old Feb 26, 2004 | 11:20 PM
maddog56's Avatar
Farmstud, what octane are you running in your raptor?
Old Feb 26, 2004 | 11:59 PM
Thankyou maddog56 you give good information mayby you can answer me this---> Whats the difference between a big bore kit and a cam, piston, and gaskett? i think the first one is good for me and my local shop bores out the cylinders..another ? ---> do i have to take the motor out of the frame for them to bore it out or does the peice that i have to bore come out easy? Thankyou so much -Matt-
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
