04 BANSHEE QUESTION (BANSHEE OWNERS ONLY)
Old Feb 28, 2004 | 02:22 PM
bansheecraze32's Avatar
Default 04 BANSHEE QUESTION (BANSHEE OWNERS ONLY)
Hi guys I just got my new 04 banshee which is still all stock. First off I love it, But When I stop for a second or two it will either stall or load up. I did raise the idle a little as I was low, But it will still stall. Please let me know if this is normal. I'm getting t-5 pipe lit next week along with a better air filter.
Old Feb 28, 2004 | 02:33 PM
RoostItUp's Avatar
I'd say it's either your air/fuel mix or your pilot jets are a little clogged up. This is a wierd circumstance cause it's a brand new quad right? It shouldn't have problems like this. Instead of you tryin to fix it just take it back to the dealership under warranty.
Old Feb 28, 2004 | 02:37 PM
KILLERCUDA's Avatar
Hey Hey now I thought he said Shee owners only? Ah well I agree with Bubba Warrior had the same prob and it was Air Fuel. Piolet was fine. She would sometimes die at idle.
Old Feb 28, 2004 | 02:40 PM
garyc660R's Avatar
Since owning Banshee's in the past and riding my bro's as much as my Raptor...I can probably chime in. First off....the Banshee has no low end....if you are trying too lug it around and then stopping it will definately stall. Keep it cleared out by RPM's and use mid range-top end power. If you are doing this and still having the stalling problem...have the dealer fix it. Don't accept a problem on a new atv. Congrats on the new ride and welcome too the 'connection forums. You will love your Banshee when you start modding it.
Old Feb 29, 2004 | 10:53 PM
lapeerbanshee's Avatar
you didnt foul your plugs because if mine has any build up at all then it does the same thing.
Old Feb 29, 2004 | 10:57 PM
KILLEREX's Avatar
how did you raise the idle? did you touch the t.o.r.s on top of the carbs?
Old Mar 1, 2004 | 07:29 AM
With the idle screws.. That TORS will all be gone in a week or 2. I'm waiting for the kit and new t-5's [img]i/expressions/face-icon-small-smile.gif[/img] . Are you headed to plastow nh next week?
Old Mar 1, 2004 | 10:28 PM
KILLEREX's Avatar
i should be there on sunday if i dont have to work
Old Mar 1, 2004 | 10:54 PM
Sheesnojoke's Avatar
If your shee is still stock,then i'd be willing to bet the fuel mixture needs to be richened.Check your mixture screws.Stock they should be 2 turns out,but depending on how cool it is outside,they may need to be screwed in 1/2 to 1 full turn on each carb.Alot of people don't pay enough attention to their pilot screws and from the factory there always on the lean side.try turning them in an 1/8 turn at a time and see if that clears it up.You may have to reset the idle screws after you adjust the mixture screw.
I make adjustment to the pilot screw everytime I ride to adjust for the atmospheric conditions.The slightest adjustment of 1/8 turn makes a world of difference.Once you've ridden it enough,you'll know when it wants an adjustment..Generally,when it gets colder out,it will need the slightest enrichenment.
It sounds like a pain in the butt to constantly make adjustments,but if temps vary and your looking for the best performance,then take the extra minute to dial it in.
My 01 ran like poop from the dealer,You had to really get the revs up to pop the clutch out without stalling,not to mention it wouldn't idle for more than 10 seconds.My screws were set at 2 1/2 turns out and I had to turn screw them in 3/4 of a turn to get rid of the bog on take off.
Old Mar 1, 2004 | 11:02 PM
Thanks alot for that tip. I did adjust that also and it seems great now.[img]i/expressions/face-icon-small-smile.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
