GYT-R exhaust problems...
Old Feb 29, 2004 | 06:15 PM
AlphaRaptor660R's Avatar
Default GYT-R exhaust problems...
Just got back from Glamis and for the second time in less than 2 months, the spark arrestor in my gyt-r silencer has blown off. The only remaining piece is the ring that holds it in place. I'm not sure what's causing it to be blown off. All I have is your basic mods, slip-on, k&n, running with the lid on minus snorkel. And I'm not sure but I think I'm jetted at 150,155, stock needles, and I can't remember what my pilots are set to, but its whatever comes with the gyt-r jet kit.
Anyway, if anyone has a guess or an idea of what's causing this, I'd really appreciate the input. Thanks.
Old Feb 29, 2004 | 10:15 PM
2strokeDiehard's Avatar
I'm not sure what is causing it but have seen a couple Raptors and now a YZF 450 do it often. I started buying the Pro Circuit T4 spark arrestors and grinding the ring down to fit. They are allot cheaper and seem to last longer. I did epoxy one of the GYT-Rs screen to the ring right when I bought it and that seems to hold up better. Its just another Yamaha flaw I guess. Worst part is I put a T4 on a raptor about 2 years ago and he has had no problems. I think the perforated tube must be rattling around in there and chafing the screen
Old Feb 29, 2004 | 11:11 PM
Guido39's Avatar
I have seen a post on another site about the same problem. I've had mine out on one long weekend so far and some smaller rides with no problems. I'll be duning 4 days next weekend so we'll see if it lasts. Others have had theirs for months with no problems so might just be bad luck...
Old Feb 29, 2004 | 11:20 PM
MNRAP's Avatar
I've went thru 2 of them with my YFZ. I've yet to figure out a way to make them last over 10 hours. I 'also tried applying J&B weld to one that was starting to seperate from the ring and that helped for a while. Wondering if the spark arrestor requires a spacer between it and the internal exhaust tube to prenet any rubbing/wear???
Old Feb 29, 2004 | 11:31 PM
Guido39's Avatar
MNRAP...what did you do to replace them? Did you buy them from Yamaha or make your own?
Old Mar 1, 2004 | 02:21 PM
Well, at least I'm not alone in this. But for 30 bucks a pop, it's definitely not worth it. I only had about 3 hours of riding time with the new Spark Arrestor before the darn thing blew off. Maybe it's time I change to a new system. Maybe Yosh or Sparks....
Old Mar 1, 2004 | 02:23 PM
MNRAP's Avatar
Bob at Magnolia Tractor sells them.. plus any Yamaha dealer should be able to order one for you..
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
