Drill wolverine clutch weights
Old Mar 5, 2004 | 09:43 AM
Lucky13's Avatar
Default Drill wolverine clutch weights
I was wondering, I wanted to make my stock semiauto clutch engage at a little higher rpm on my 2001 wolverine. Will this give me back some of the low end bite I'm looking for? How do you drill it(size hole, where at, etc..) or how much does just putting heavy duty clutch springs accomplish?
lucky13
2001 wolverine
high comp piston .020 over
white brother cam
e-series pipe with 8 disc
re-jetted carb
heavy duty valve springs
Old Mar 5, 2004 | 06:41 PM
eja's Avatar
eja
I don't see any info yet Lucky 13. I don't have any either but am also interested. Would adjusting the increase- decrease control do anything to change when the clutch engages.
Old Mar 5, 2004 | 06:43 PM
Eceriderjbomb's Avatar
lucky i see in your signiture that you did end up buying the heavy duty cluth springs. How do they perfrom?
Old Mar 7, 2004 | 12:19 AM
95wolv's Avatar
The clutch weight mod is a 3/16" hole drilled as near to the end of the weight shoe as possible, do NOT drill out the rivet hole, and use the first weight you drill as your template,use it to mark the spot on the other weights to make sure you put the hole on the same spot on every weight, to make sure the engagement is even. This will raise the rpm by about 400, makes a difference with bigger tires, and won't hurt top end.
Old Mar 8, 2004 | 03:00 PM
wickedwolf's Avatar
Does this add a noticeable amount of low end for bigger tires. Also does this weaken them to where they could possibly break in the future.
Old Mar 8, 2004 | 04:10 PM
Lucky13's Avatar
i didn't do the clutch springs(it says valve springs). I'm trying to determine which will work better. If I drill the clutch weights, that should give some pretty good bite back, especially with stock size tires, shouldn't it?
let me know. Sounds like a lot of people are kinda interested in doing this mod.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 26, 2004 | 12:29 PM
Lucky13's Avatar
do you need any special tools to pull the clutch out to drill the shoes? Is there anything else I will need, gasket so that I can have everything at once? Is drill the clutch weight a hard mod to do? It doesn't sound bad.
Lucky13
2001 wolverine
e-series silencer
air box uni-filters
white brother power filter
.020 wisco piston
re-jetted carb
valve springs
Clutch springs & clutch weights drilled?(thinking strong about it)
also thinking about warn 424
buddieboy
Dec 9, 2016 05:50 PM
Robinhood
Dec 26, 2015 10:28 AM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
