Need a better spark plug?
Old Mar 6, 2004 | 05:39 PM
03shee's Avatar
Default Need a better spark plug?
Trying to find a hotter plug for a banshee. I can find the plugs but their are no cross reference #. Anybody know the # for a hotter ngk plug. The stock one is BR8ES, so whats the hotter plug #? thanks
Old Mar 6, 2004 | 09:27 PM
Slowwarrior's Avatar
NGK's site Click there and look on the bottom left it says ngk numbering system that will open a window and explain it.
Old Mar 6, 2004 | 10:44 PM
Hiram's Avatar
BR7ES is what you are looking for, the lower the center number the hotter the plug, and the higher the number the colder the plug
Old Mar 7, 2004 | 02:48 AM
What are the benefits of using a hotter or colder spark plug?
Old Mar 7, 2004 | 04:34 PM
TRLYFZ450's Avatar
A hotter plug will give you better low end power and will melt you pistons on top end.
Old Mar 7, 2004 | 05:17 PM
hondabuster's Avatar
well.....not quite.
Spark plugs dont generate heat, they just remove heat. A hotter plug retains more heat than a colder plug, which if you have problems with deposits on the plug, will help to burn them off. If you have an older tired motor, and oil is geting by the rings, a hotter plug will help buy time til you rebuild the motor.
Old Mar 7, 2004 | 07:26 PM
TRLYFZ450's Avatar
Originally posted by: hondabuster
well.....not quite.
I was talking about my banshee when i put in hotter plugs and burned a hole in my pistons [img]i/expressions/face-icon-small-sad.gif[/img]. But they were splitfire plugs.
I will never use splitfire plugs in anything again![img]i/expressions/face-icon-small-mad.gif[/img].
Old Mar 7, 2004 | 07:36 PM
Chilly's Avatar
Check it out..
NGK Tech Tips
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
