Porting Mod Banshee
Old Mar 6, 2004 | 10:44 PM
FMF's Avatar
FMF
Default Porting Mod Banshee
I am going to put in a Vitos Top end Kit and I also am going to do some Porting on it.
Were can I get porting Tamplates? And should I put the Super Stock Pistons in or the Power Pistons?
Old Mar 6, 2004 | 10:48 PM
Hiram's Avatar
RaceLogic.com has nice ones for $89 and I would go with the Power Pistons since you are porting and will be raising the exhuast timing some and the Super Stock Pistons also raise the exhuast timing so this will just be too much in my opinion.
Old Mar 6, 2004 | 11:37 PM
FMF's Avatar
FMF
Thanks
I will go with the Sportport and Vitos Power Pistons.
My Mods that I have Know
FMF Fatty Pipes
FMF Power Core 2
Boost Bottle
Pro Flow Intake
6 Filtered Air Vents
V-Force Delta 2
Dirtdigger Clutch kit
Vitos Super Stock Pistons
Vitos Degree Key
Pro Design Cool Head
21cc Domes
28 Flat Side Carbs
Old Mar 7, 2004 | 12:32 AM
JakalWarrior's Avatar
If your doing the porting yourself, it would probably be best if you just raised the exhaust a degree or two then cleaned them all up. That way you wont mess it up tp where somone else can't port it. There is more to porting than just cutting the sleeve. You have to shape the ports right, get the angles right, and know the little tricks.
Old Mar 7, 2004 | 12:42 AM
sooperfly's Avatar
I have used the sport port kit with no problems at all. For the money, it is well worth it. I ported my own banshee last winter and am finishing my brothers right now. If you are interested in buying the templates or have any questions go ahead and e-mail me at allrwill@otc.isu.edu.
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
