warrior problem
Old Mar 9, 2004 | 03:46 AM
much2fear's Avatar
Default warrior problem
i own a 1988 yamaha warrior with a white brothers exaust and a K&N air filter. I have a problem with it......it is always crappin out in the higher RPM's it dosent really lose any speed but it is definetly annoying......does anybody know what I can do to fix this problem?
Old Mar 9, 2004 | 07:26 AM
NLWarrior01's Avatar
Define "Crappin Out"
If you're not loosing speed, then you're not loosing power *unless you're coasting downhill*, and you have no problem ...
Need a lot more info to start helping you.
Old Mar 9, 2004 | 07:02 PM
much2fear's Avatar
i dont know exactly how to explain it but crappin out is like sputtering in the high rpm ...im kinda new to all this quad stuff so i need help please
Old Mar 9, 2004 | 07:52 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
try readjusting valvues or chec kyour jetting
Old Mar 11, 2004 | 02:54 AM
much2fear's Avatar
ok ill try that. there is another thing i wanted to ask.....it seems like its using gas a little fast, is that because of the exaust or is there something wrong?
Old Mar 12, 2004 | 03:28 PM
98yamyz's Avatar
pull your spark plug if it it whitish you are running lean try changing your main jet to a 150 or a 155 if your plug is black not brown i mean black change your main jet down in size this should help
Old Mar 12, 2004 | 04:30 PM
Warrior350CR's Avatar
much2fear,
There are many things that can cause this.
First off, are the K&N filter and the White Brothers exhaust new? Did the problem happen after you added them?
Did you change jets? You will most likely need to go from the stock 145 main to a 150 or 152.5 depending on altitude. Check your plug color to estimate if your rich , lean or ok.
Do you hear valve ticking? If so adjust them. I would also check that the K&N is clean, a clogged filter will cause the motor to go rich.
Old Mar 12, 2004 | 04:37 PM
sAyIt_fmf's Avatar
Are you sure your not hitting the rev limiter? Does it wind out in gear and then start to sputter until you shift again?
If that's the case, you are reaching the rev limiter.
Old Mar 13, 2004 | 10:49 AM
TRLYFZ450's Avatar
Check the wire that’s on the reverse lever for a good connection. If it looses its connection it will start to miss a higher RPM's.
I would remove the wire and relocate it. Try to get it attached to the motor. I ran my wire to the ground from the battery where it attached to the motor. Hope this helps.
Old Mar 13, 2004 | 11:05 AM
warrior68man's Avatar
sounds like its running to rich, check you filter to see if its clogged, try different jets, its all about trial and error.
