warrior problem
Old Mar 13, 2004 | 12:25 PM
NLWarrior01's Avatar
Default warrior problem
Originally posted by: sAyIt_fmf
Are you sure your not hitting the rev limiter? Does it wind out in gear and then start to sputter until you shift again?
If that's the case, you are reaching the rev limiter.
Warrior'd don't have a rev limiter.
Old Mar 13, 2004 | 12:30 PM
Eceriderjbomb's Avatar
Did you ever rejett when you got your ehuast. Check your airbox for dirt and resadue.
jbomb
Old Mar 14, 2004 | 02:32 AM
much2fear's Avatar
the person i bought it from already had the air filter and exaust on it so i dont know what they did to it.......my air filter is clean
Old Mar 14, 2004 | 03:35 AM
much2fear's Avatar
if it had a rev limiter where would it be located on the quad?
Old Mar 16, 2004 | 09:29 AM
  #15
sAyIt_fmf's Avatar
You sure about that?
Old Mar 16, 2004 | 09:47 AM
  #16
Positive. Ask Mickey Dunlap, if you can find him here on the forums.
Old Mar 16, 2004 | 10:11 AM
  #17
waynaferd's Avatar
My cousin had the same prob on his modded 02, and all it was was the parking brake safety thing. Just make sure its pushed back all the way (you know, the thing on the clutch lever)
Old Mar 16, 2004 | 10:16 AM
  #18
sAyIt_fmf's Avatar
So what your saying is that yamaha built an atv that will allow you to rev it until it grenades? It could be true...I just find it hard to believe.
I'm going to look into this more considering I had a warrior...time to check the book. (well..whenI get out of work)
Old Mar 16, 2004 | 10:23 AM
  #19
The thing with the warrior is the valve train on it is poor. What happens when you get up high in the RPM's is the valves start to float, unable to keep up with the demands of the engine. At that point you're starting to loose power and the ability to sustain the revs. I don't know what RPM this starts happening at, but most anyone with any real experience with the Warrior engines will tell you, there's no rev limiter on them, because with the stock internals it's just not able to rev all that fast. Not to say it doesn't need one for doing internal mods which would enable the engine to rev higher (i.e. stiffer springs) though. I'm not experienced with the Warrior engine myself, or any engine for that matter. Just going on what I've read and learned through this forum.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
