Tors removal kit
Old Mar 10, 2004 | 08:59 AM
Shav0's Avatar
Default Tors removal kit
What all is involved in this kit for a blaster? Why do you need a drill bit that it shows in the picture, what is that for?
Old Mar 10, 2004 | 09:12 AM
2003warrior's Avatar
i was just looking at one of those for my banshee. the drill bit is to drill into the side of your carb where the idle screw is supposed to go and the tap is to tap the hole so the idle screw will screw in.
where are u getting your tors kit from?
Old Mar 10, 2004 | 09:30 AM
Shav0's Avatar
why do you need to have a idle screw?
I was going to order from VITOS but they told me they cant ship to canada. So instead i am going to order from a company in quebec. If i order from them it dosnt all come in a kit and i will have to order it seperate. Why do you need a throttle cable what is different about it?
Old Mar 10, 2004 | 09:40 AM
sAyIt_fmf's Avatar
You will need the idle kit...if it is not there then the slide in the carb will bottom out and the bike will not idle or even start with out you holding the throttle.
The kit comes with a new cable because the sleeving on the stock cable will be too short once you remove the tors. Plus the carb cap on the tors is not usable with the cable alone.
Old Mar 10, 2004 | 09:45 AM
Shav0's Avatar
I have got most of the parts that i would need except for the cable.
can i just order a throttle cable for a 26mm carb? or will they send me one that is for the tors?
Old Mar 10, 2004 | 10:32 AM
sAyIt_fmf's Avatar
If I were you...I would call the company and ask them...tell them it is not for a stock tors setup...and you will need the cap as well
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
