people with 686 and 727
Old Mar 10, 2004 | 05:58 PM
XTraptor's Avatar
Default people with 686 and 727
what kind of rod are you guys running?
are you running stock carbs?
if you are running an aftermarket rod, did you get the crank balanced with the new rod?
how bad is it to run an aftermarket rod without balancing the crank?/
thanks
Ahmed
Old Mar 10, 2004 | 06:11 PM
RAPTORAZ's Avatar
thanks
Ahmed
Rod = Carrillo
Carb's = modified stockers
Balanced = Yes (lightened too)
Old Mar 10, 2004 | 06:19 PM
1BADRAPTOR's Avatar
ROD=carillo
CARBS=Lectron
Sent to falicon for balancing...
and you would never want to run a unbalanced rod,probabley the worst you can do,a whole mess of problems arise fro it being out of balance..
Old Mar 13, 2004 | 12:40 AM
ccgrady's Avatar
stock crank, stock rod and stock carbs. unless your around sea level the stock carbs will work just fine.
Old Mar 13, 2004 | 01:00 AM
Yamaha660R's Avatar
Rod - B&W Industries
Crank Work - Falicon
Carb's - Modified Stockers(switching to FCR's sometime in summer)
With a 686, you don't have to change the rod, and balence the crank but it's a good idea. It's definetly something you should consider to give you piece at mind.
With a 727, it's a must. No question. Aftermarket carb's, rod, and Falicon Crank Work.
Old Mar 13, 2004 | 01:02 AM
Yamaha660R's Avatar
By the way, my B&W Rod is a Chromoly Rod.
Old Mar 13, 2004 | 02:41 AM
BigScary's Avatar
how can I get up with B&W?
Old Mar 13, 2004 | 02:53 AM
Yamaha660R's Avatar
Contact Bob Craycraft. He carries the B&W Rod's. He also has a titanium rod...although it is very very pricey.
Old Mar 13, 2004 | 10:54 AM
Ernie660R's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]
shimanok2
Jan 29, 2016 07:37 PM
kbazzy
Sep 26, 2015 11:26 AM
Irishman301
Sep 23, 2015 01:47 PM
01ssls1
Sep 22, 2015 06:50 AM
Elkaholic
Sep 6, 2015 02:44 PM
