WARRIOR FUEL TANK PROBLEM
Old Jul 12, 2000 | 06:58 PM
ferd350CT's Avatar
WHEN I PUT FUEL LEVER ON RESERVE QUAD DIES,MY GUESS IS BAD RESERVE GAS ?? WILL REMOVING FUEL LINE AND DRAINING REMOVE ALL GAS OR DO I HAVE TO TAKE TANK OFF. ONCE IT IS PUT IN RESERVE IT IS VERY VERY DIFFICULT TO START. 1997 WARRIOR.
Old Jul 12, 2000 | 09:38 PM
hot_shoe_cv's Avatar
You can drain the fuel, but not for the reason you think. It would be to allow you to remove the petcock & inspect the operation of IT when turned to reserve. It sounds like it is plugged & not allowing fuel to flow from that setting. The reserve setting is not a separate fuel supply..it merely is a divided portion of the tank that holds a small portion of the fuel in the tank. When the fuel in the "run " side of the tank drops below this divider you simply switch to reserve. In normal riding the fuel sloshes back & forth over the top of this divider so it is all the same fuel.
By the way..please lose the caps.. IT SOUNDS LIKE YOU ARE YELLING AT US!
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
Shifts
Jul 3, 2015 07:59 AM
