Decompression Pin in Raptor Motor ----
Old Mar 29, 2004 | 07:18 PM
  #31
CTracingraptor's Avatar
Default Decompression Pin in Raptor Motor ----
When i try to push the decomp pin in with like the end of a ratchet it will not move the weights, my rocker arm has no gashes in it, just normal wear marks it appears nothing deep enough to feel with my fingers.
Old Mar 29, 2004 | 09:08 PM
  #32
Ugintel's Avatar
OK, go to this page
http://216.37.204.206/alba/Yamaha_OE...e=13&A=216&B=3
then look at part 5 on the cam shaft, you can rotate that 180 Deg. amd it will work, but it will push the pin up when you hit the right RPM instead of dropping it down. If you read a maual it will tell you how to PUT it back in, ALSO you need to make sure your timing chains on right with the cam, if you moved the sprocket and then put it back togeather you have to use a socket set and get the timing all back right, WICH A MANUAL WILL TELL YOU HOW DO TO.
Old Mar 29, 2004 | 09:52 PM
  #33
wshrdskin's Avatar
When you install the cam, part #5 the lever has a dot on the end of it where the two **** are. When the **** are between the weights in their grooves, the dot on part #5 will be at a 12 O clock position in reference to the top of the head. The decompression pin should be sticking out of its hole a little at this time also. Seperate the weights and the lever spins a little and the pin goes back into it's hole.
Old Mar 29, 2004 | 10:08 PM
  #34
RaptorOwner's Avatar
You know what guys, this would be cool if Raptortranny had pics of this installed on their website.... Just an fyi....
Kaleb_00
Jun 1, 2016 09:15 AM
goosemasterkl
Aug 23, 2015 11:36 AM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
