Banshee compression?
Old Mar 20, 2004 | 10:52 AM
joeiii3's Avatar
Default Banshee compression?
what range should the compression be and still be ok. What is the compression after a typical rebuilt. I just checked mine and both cylinders are at 105 after I have warmed up the engine.
Thanks for the help
Joe
Old Mar 20, 2004 | 01:59 PM
joeiii3's Avatar
Any help guys?
Old Mar 20, 2004 | 03:39 PM
Buttermilk385's Avatar
I believe that compression on a stock banshee would be in the 120-125 psi range.
I always check mine cold (I don't warm up the motor prior to checking it). I also run my motors with a lot more compression than stock.
Regards,
buttermilk
Old Mar 20, 2004 | 03:46 PM
roosthrower's Avatar
whats your elevation joeiii3?
Old Mar 22, 2004 | 11:27 AM
joeiii3's Avatar
I am in northern Ilinois. I don't know the elevation here but, It cann't be very high.
Old Mar 22, 2004 | 09:30 PM
borrow a friends compression tester. If it says 105 too, you probably have some problems.
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
