Starting problem on Rappy
Old Mar 23, 2004 | 11:29 PM
  #21
Mr45auto's Avatar
Default Starting problem on Rappy
If you jump start it from another battery will it crank right up? If so you might consider a better battery. My YTX14 (stock) wouldnt do my 12:1 686 worth beans. I upgraded to a YTX20L-BS from www.discountmotorcyclebattery.com and no more problems. It starts right up. I owe that to Patsraptor if memory serves me right. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 23, 2004 | 11:31 PM
  #22
yamahatheonlyway's Avatar
well guys, i live in wisconsin where is it very cold this time of year, i got the same problem u guys are talking about, starter goes very slow, i changed my oil to thinner stuff, it works fine now and starts, so try thinner oil......
Old Mar 23, 2004 | 11:42 PM
  #23
RoostItUp's Avatar
Would it drain the volts way down when you tried to start it? Also would it eventually stop working if you tried to turn it over a few times to the point where you have to charge it again?
Old Mar 23, 2004 | 11:48 PM
  #24
Mr45auto's Avatar
Mine cranked really slowly even after a fresh charging. It would barely turn over and when it hit the compression stroke it would flat stop. I'd have to let off the starter button and hit again a couple times to bump it past the compression stroke. It would also drain the battery very quickly doing this. Jump start it from your car/truck and see if it cranks right up or turns slowly.
Old Mar 23, 2004 | 11:52 PM
  #25
RoostItUp's Avatar
It does turn over if jumped...I had to do it a couple times a couple weekends ago. Also, I have a charger hooked up to the battery and with that extra juice it starts up but if I take it off it doesnt turn it over well, if at all.
Old Mar 23, 2004 | 11:53 PM
  #26
Mr45auto's Avatar
How far are you from Oregon City? I'd be happy to let you try my battery, it's the cheapest route.
Old Mar 23, 2004 | 11:58 PM
  #27
RoostItUp's Avatar
I'm right outside Eugene, I think thats a ways away. I was planning on taking back that battery tomorrow, It's not holding the volts I need so I'm assuming it's faulty. I'm gonna go get another one similar to the one you have also tomorrow after I take that back. Hopefully it will work then. They should take that battery back right?
Old Mar 24, 2004 | 12:00 AM
  #28
Mr45auto's Avatar
I would think they'd take it back if there is a fault in the battery. It's definitely worth the upgrade. You'll have to fiddle with the wiring a bit to get the YTX20 to work out but it's not terribly difficult. I think it's the OEM grizzly battery.
Old Mar 24, 2004 | 12:30 AM
  #29
RoostItUp's Avatar
How do you mean "fiddle" with the wiring? What do I have to do?
Old Mar 24, 2004 | 12:31 AM
  #30
BigScary's Avatar
if you can't figure anything out.......you may check the decompression pin on that blasted hot cam.......
