piston help?
Old Mar 21, 2004 | 06:27 PM
wanaply21's Avatar
Default piston help?
ok im trying to get my cylinder out and have never messed with anything internal, ok will somebody tell me how to take a stock piston out of a stock head, do i need a special tool to get it out, and is it difficult? i will be sending it 2 hollywood dirt productions to be ported could i get some info ASAP! thx everyone!
Old Mar 21, 2004 | 06:38 PM
Gotti2k4's Avatar
when taking the jug off...u take the carb, and exhaust off. then take the 4 nuts that hold the jug to the case, carefully slide the jug off of the piston. easy if you take the fuel tank off. the piston will stay attached to the rod and crank. If you are getting it bored over, there are c clips on each side of the piston wrist pin, take these of with a small pair of needle nose, and be sure not to drop anything into the case, cover it with some clean rags or so. Slide the wrist pin out of the side you took the c clip off and the piston will come off the rod. Very easy, after youve done it once. Its simple after that.
Old Mar 21, 2004 | 06:40 PM
wanaply21's Avatar
can i take it off with the piston being at any point or where would it need to be positioned?
Old Mar 21, 2004 | 07:05 PM
wanaply21's Avatar
that was easy thx alot dude but i had to get the wrist pin out with a screw driver and a hammer but tapping it very lightly it came out only cuz i couldnt get it out with my fingers
Old Mar 22, 2004 | 05:43 PM
Gotti2k4's Avatar
The only thing you have to make sure of is that you get the piston put back in with the arrow pointing forwards. and that the two holes on the skirt of the piston is facing back. that is the intake side of the piston. Yes sometimes the wristpin is alittle tight in there. Tapping it out is ok, just as long as you tap it lightly. it should budge...
Old Mar 22, 2004 | 06:41 PM
Raptorboy4life's Avatar
I took out my friends and we had to bang the he!! out of it for it to come out (the wristpin) and then it came out! would it hurt anything?
Old Mar 22, 2004 | 10:25 PM
Gotti2k4's Avatar
i dont know if it could or not. Depending on what it was. id imagine if you hit it hard enough you could prolly tweak the rod. Prolly have to hit it pretty hard..but im sure it could happen
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
