what exactly does a warn 424 do
Old Mar 21, 2004 | 10:31 PM
UltimateAussie's Avatar
Default what exactly does a warn 424 do
I am going to get either a warrior or a wolverine soon and people have told me i should put a warn 424 on a wolverine if i get one what do these do. and how much do they cost. thanks
Old Mar 21, 2004 | 10:39 PM
maddog56's Avatar
a 424 will allow you to take the wolvie out of 4wd. They run about 250 bucks.
Old Mar 22, 2004 | 12:31 PM
do they fit all years of wolverines from like 94 up. and does it let you go back to 4 wheel drive without a wrench or having to get off the bike.
Old Mar 22, 2004 | 12:49 PM
badchad's Avatar
Yes, you can go from 2 to 4 wheel drive on the fly (less than 3 MPH recommended). It replaces the stock shaft coming off the engine allowing it to disengage the front wheels. It has a cable that runs to the top of your quad and you simply turn the **** to release it, pull or push the **** in or out and twist it again to lock it in or out.
Old Mar 22, 2004 | 03:29 PM
EasterEgg's Avatar
However the teflon bushing used to engage/disengage wears out quickly. They can be replaced easily and cheaply enough but it could leave you stuck in 2wd. This is what happened to a friend who had one, he wore the bushing out in less than 100 miles of mud riding at Wayne NF. Had to finish the trip with a 26" tire equiped 2wd Wolverine.
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
