best 686 combo?
Old Mar 23, 2004 | 01:58 PM
appraptor's Avatar
Default best 686 combo?
What all is everyone's opinion on the best combination for the 686 kit. I was planning on stage 2 cam, 11:1 JE piston, kibblewhite springs, and 1mm oversize valves. What does the stage 2 cam give you over the stage 1? Is it very noticeable?
Thanks in advance
Old Mar 23, 2004 | 02:04 PM
Dfitz's Avatar
Have you done a search yet. There is a days worth of reading if you look.
Old Mar 23, 2004 | 02:08 PM
appraptor's Avatar
yes, a little but I'm mainly concerned with any problems with a particular configuration
Old Mar 23, 2004 | 02:20 PM
BigScary's Avatar
I dislike the stage 1 cam....when i upgraded to the stage 2 I noticed a HUGE power gain.........though i did go from stock bore 11:1 to 102mm 11:1, I gained some on the bottom, a good bit in the midrange, and a LOT on top.........
if you are going to run the JE 11:1 you will have to run race fuel.......you may as well step up to the 12.5:1......
Old Mar 23, 2004 | 02:26 PM
appraptor's Avatar
From what I understand, the stage 2 and 11:1 JE is the best all around powerband gains so that is why I stuck with the 11:1. Also, how do the stock valves hold up when using the stage 2, 11:1? should I go ahead and replace the valves now or wait? What about the rod?
Old Mar 23, 2004 | 03:01 PM
BigScary's Avatar
from a reliabitlity stand point, I would leave the valves and change the rod......Forget about the JE and get a Ross or CP piston
I'm scared of the JE pistons.........
Old Mar 23, 2004 | 03:23 PM
appraptor's Avatar
won't the valves crap out shortly after getting beat to death with the stiffer springs? Too late for the piston...I bought a 686 cylinder and ceramic coated 11:1 piston together so that is what I have to work with.
Old Mar 23, 2004 | 03:33 PM
garyc660R's Avatar
The stage 2 cam requires stiffer valve springs. Most people with the 10.75/1 JE piston get by on premium pump fuel. I know my stock bore 10.75/1 JE Raptor had no problem with premium fuel. I do run a bit rich and 1 shade colder on the plug though. Race fuel is a pain too find for most people...and a lot more expense. Anyone have a stage 2 - 10.75/1 686 (equivalent or better) that is rode at least once a week that lasted over a year? 2 years?
Old Mar 23, 2004 | 03:38 PM
DUNERIDER33's Avatar
I would go with the carillo rod it's the best. I would also go with ferrera valves +1mm. that is what I am putting on my bike with all the other stuff you metion in your post.
Old Mar 23, 2004 | 04:49 PM
Yamaha660R's Avatar
You should change the rod and the valve springs. Definetly the rod if you are going to a 686, and definetly change the springs if you are running a Stage 2 cam.
I have a similar set up as yours, but Craycraft has done all the work, and Falicon balanced the crank. So give me a week or so, and I'll let you know exactly how it runs...of course I'll have 35mm FCR's, so that will help alittle.
