sprokets
Old Mar 25, 2004 | 09:55 PM
Rider1169's Avatar
Default sprokets
how much more top end will u have on a raptor if u add a tooth to ur front sprocket. how hard is it to change front sprockets on them? thanks-paul
Old Mar 25, 2004 | 10:13 PM
Hozed's Avatar
Default sprokets
probably wont gain too much... and they arent that hard to change... just gotta loosen the chain as much as you can and take all the chain guards off... then the sprocket. less than 30 minutes if you have any mechanical ability.
Old Mar 25, 2004 | 10:15 PM
Rider1169's Avatar
Default sprokets
like + 5mph? and on the torquey raptor, will it really decrease acceleration that much? what about if i add 2 to the front. i am only talking about the front because i hear they are cheaper.
Old Mar 25, 2004 | 10:19 PM
Hozed's Avatar
Default sprokets
ya probably around 5ish...
you will loose alot of acceleration with +2 in the front... the front is cheaper...
but how often do you hit your top speed? there is no sense in adding bigger sprockets just to be "faster" on top.
Old Mar 25, 2004 | 10:27 PM
Rider1169's Avatar
Default sprokets
yes, i agree, but, if adding 1 will give me a 5mph more top end, and not take away any accel, i would rather do that, adding 2 is way to much tho.
Old Mar 25, 2004 | 10:41 PM
Hozed's Avatar
Default sprokets
1 tooth will make it slower until top speed...
Old Mar 25, 2004 | 10:43 PM
Rider1169's Avatar
Default sprokets
i read tho that the raptor has so much power it can pull taller gearing with ease
Old Mar 25, 2004 | 10:47 PM
Hozed's Avatar
Default sprokets
i have no doubts about that... but it wont be as fast as if you had a stock or smaller sprocket on it...
Old Mar 25, 2004 | 11:24 PM
dvf's Avatar
dvf
Default sprokets
I went down 1 tooth on the frt and didn't loose too much top end but gain alot of low end well worth it in i think Sorry don't know about going up a tooth just tought it might help
Old Mar 26, 2004 | 11:01 PM
Rider1169's Avatar
Default sprokets
how mcuh more low end did u get, if u can give me an example. and how much top end did u loose, or couldnt u really tell?thanks
