Need Help Quick!! Warrior bolt prob!
Old Mar 26, 2004 | 07:25 PM
warrior68man's Avatar
Default Need Help Quick!! Warrior bolt prob!
Front Left brakes.....bolt to take the pads off...theres 2 allen bolts....i got one free..other one...would not come lose...so i ended up rounding it off it doesnt stick out so im not sure how to get it out.....trying to replace front brake pads lol...anyone help....my dad doesn't know what else to do...
Old Mar 26, 2004 | 07:31 PM
KGB's Avatar
KGB
Obvioulsy try the old wd-40 and let it soak trick.
After that , can you get into it with a dremel and small cut off wheel? I have cut a slot in stripped bolts and remove with a reg screwdriver. You can try to drill it out. You can get a easy out, but usually they just break too, if they break off they are pretty hard to drill. Last resort is to weld a bolt to it and back it off.
Good luck.
ReignMan's Avatar
your best bet will be to drill it out and buy a new screw.
Old Mar 26, 2004 | 07:43 PM
I put liquid wrench on it before i tried to get it out...i will try the grinding wheel thing with the dremel.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Rooky
Sep 9, 2015 03:16 AM
