Just got 2002 banshee carb HELP!
In the carb is the choke side piece aorund the needle supose to be longer and go down farther than the right side?.. could that bew why its poppen when i let off the gas?... I put new plugs then after a while left side choke side starting poppen, And it runs liek crap.. I dont understand It ran fine with new plugs then started runnen like crap, Has fmf gold series header pipes, and Power core 2 silencers
Since you have two carbs, you have to make sure they are working together perfectly. Take your airbox and airfilter off the back of your carbs so you can see the slides. Then push the throttle, both slides should come up at the same exact time. If one comes up a little bit sooner than the other one, they need to be adjusted. Go to the Banshee HQ Forums and ask about it there, you will get all the answers you need. I am not fimiliar on how to adjust the carbs with stock TORS on them.
Ok, will check that today. But are the slides the same size and come down in the same spot, mine dont i had it off. The right side runs good but shoots flames sometimes. But the right jsut pops and dosent run right i was told wiring too.IS THERE ANY WAY I COULD OF DROPPED OR MESSED UP INTERNALS?.... Hope not
Any clues let me kno
07-07-2015 11:00 PM
