banshee top speed
Old Mar 29, 2004 | 11:19 PM
4x4eva's Avatar
Default banshee top speed
Douse anyone know what a stock banshee's true top speed is? Also, if you pin it on a gravel road stock, will the frontend pop up or will it spin. What about on the road . . . ? Thanks
Old Mar 29, 2004 | 11:33 PM
Ish416's Avatar
I think on pavement a Banshee's top speed is around 75 - 80 MPH. On a gravel road it will spin and pop the front end up at the same time.
Old Mar 29, 2004 | 11:37 PM
roosthrower's Avatar
mine just spins on gravel. the road is the only place I can get the front end up on my shee. me shee will spin through sixth gear on gravel.
Old Mar 29, 2004 | 11:44 PM
AnimalMother85's Avatar
mine comes up in 4th gear on mine, on my road, but dirt, it spins a bit, and just goes
Old Mar 30, 2004 | 12:02 AM
2untouchables690's Avatar
well it's illegal for a quad out of the factory to do over 78, the banshee only does about 72mph stock but you can get some minor mods and a bigger front sprocket and then you are easily breaking 80
Old Mar 30, 2004 | 12:32 AM
MrG's Avatar
MrG
you can make your banshee spin anywhere if u wanted. On gravel it will spin just a little though. On dirt it spins crazy but fun. You can pop wheelies anywhere u get traction (dunes with paddles, roads, grassy areas etc..) you can improve traction buying some aftermarket tires stock ones suck.
Old Mar 30, 2004 | 12:40 AM
hondaracer305's Avatar
4 mph faster than a 400ex? No dude, they are at the most 77mph stock broken in right, i hear that number more than any of em.
Old Apr 3, 2004 | 09:51 PM
lapeerbanshee's Avatar
Stock banshees go 73 mph maybe a little more on pavement. the quadzilla could do 85-90 stock so i dont know when the law came into effect that a stock ATV cant go over 78 MPH. mine spins on dirt takes about 4 seconds to get going if you hit it hard enough but my tires are pretty wore out hopefully my XCR's wont spin that fast but it comes in handy if you do alot of trail riding where you can slide around the corners.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
