banshee pistons
Old Jul 17, 2000 | 03:29 PM
BANMAN's Avatar
I think it is time to rebuild the banshee since my compression tests out at about 80# per side. It is even but it is getting low I think. (and this is with .20 shaved off the head.) My question is- Are the pistons sold by Vitos performance any better than a set of regular weiscos. I know they are about $70 more. I just want to get the compression back up to hopefully get some more low end power. THANKS ALOT
Old Jul 17, 2000 | 04:55 PM
Backcountry's Avatar
Vito's pistons are pretty good unit's. Wiseco makes them to his specs. They're light and have a higher dome on them that raises the compression. Low-end increases can be obtained thru increased compression. You do have .020 off of your head( I assume from the gasket mating surface), so I would ask Vito first if it would be safe to run on premium.
Just plain ole Pro-lites with a fresh bore will help get back alot of your missing bottom end too.
Old Jul 17, 2000 | 05:33 PM
QuadSpeed's Avatar
we just put a wiseco piston and rings in my brothers blaster and it brought the compression right back up.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
