Anyone have or seen Kenda Klaws?
I want to get rid of the Crappy stock tires on my Raptor. They roll over to much and, make sliding a rough task. I put my friends Maxxis Razors on just to try it and, it made a world of difference. They were on a 1in pers side wider offset rims but, the sidewalls were much stiffer and, made the Raptor handle a ton better. The Downer is the Razors are more expense then others.
I saw the Kenda Klaws and, wanted to know if they were similiar in performance and, side wall stiffness (anything is better than the stock tires). This way I can stick w/ the same company that makes my paddles and, save a few Duckets!
Thanks!
Thanks!
MAn i Dont have any
but a buddy of mine from the City, has some on his 400ex, with a 416kit
and he says that they were way betterl then the Razers he had befor.
And i had razers and they are a graeat tire, So if he says there better then them
then i would go for them for sure
I have a set on my Raptor. I also saw an article where they did a shootout between the Klaws, Razor and Holeshot tires. Klaws came out on top. The tires hold up very nice and I also like the idea of being able to swap them around, depending if you ride hard or sand/mud surfaces.
So is the sidewall stiffness better than the stockers on a Raptor? I'm not to worried about straightline grip since the stockers have plenty and, my front end is always in the air. I want to be able to slide better and, not have the tires roll over like the stockers do.
