Think this is true?
Old Apr 2, 2004 | 11:08 PM
AARaptor660's Avatar
Default Think this is true?
In one of my mags, Alba says that their complete motor kit will add 20 horses,any of you have this or not? Reliable, please answer this time. Thanks
Old Apr 2, 2004 | 11:11 PM
Rider1169's Avatar
for raptor? whats in the kit, if its just a pipe and filter i would say not 20hp.
Old Apr 2, 2004 | 11:37 PM
Raptorboy4life's Avatar
LOL
Old Apr 3, 2004 | 08:54 AM
lapeerbanshee's Avatar
if its a completely new top end it probably will
Old Apr 3, 2004 | 12:10 PM
It is 440 dollars and says it comes with like piston, gasket, and cam. This sounds a little fishy but if it works, hey.
Old Apr 3, 2004 | 12:26 PM
DieScarred's Avatar
I dont believe that, and I havent seen a single Alba bike run in my life.
Old Apr 3, 2004 | 04:21 PM
maddog56's Avatar
Well then I guess your input is worthless here isnt it?
Pipe and filter can add 10-14 and a cam and high comp piston can add another 4-9. But that all depends on what filter/pipe/cam/piston is put in. Alba is probably renaming someone else' parts, so you might be able to find out what you are really getting.
Is that the kit with the new valve springs as well? I believe I heard a rumour that those kits were running hc stage 2 cams.
Old Apr 3, 2004 | 05:14 PM
Yamaha660R's Avatar
You could possibly go up to 55hp with their pipe kit, piston, and cam.
The pipe kit alone gives you a big gain. So you might get a 20hp gain with the entire set up. But I would guess between 15-20 with their piston/cam and pipe kit.
Old Apr 3, 2004 | 06:35 PM
Haymaker's Avatar
Sounds feasable to me
shimanok2
Jan 29, 2016 07:37 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
