Carb HELP !?
Old Apr 3, 2004 | 10:38 PM
Warrior350ripper's Avatar
Default Carb HELP !?
Old Apr 3, 2004 | 10:40 PM
MYBAD^...... is there anyway to jet my carb after i stripped my two screws inside?
Old Apr 3, 2004 | 10:44 PM
95Wolverine's Avatar
Did you strip the screw heads or the threads?
Old Apr 3, 2004 | 10:53 PM
heads...there to room to get at em
Old Apr 4, 2004 | 09:55 AM
themadwarriorrider's Avatar
I stripped the screws also on my 2004 warrior carb. I stripped two of the bottom screw on my carb and two on the top while rejetting the carb. What I did for the two screws on top of the carb where the slide is located. I used a small ice pick and a hammer. I chiseled the screw heads on the edge and slowly backed them out. The bottom scews I used a larger chisel and backed them out. I used two screws out of another carb I had for the bottom screws and just replaced them when putting it back together. I had to order the top screws from a dealer. Mukini has the softest bolts known to man, I would never buy a carb from them due to this issue. I was gentle also and still stripped them.
04 warrior lots of mods
Old Apr 4, 2004 | 02:24 PM
does anybody know a GooD carB for a Warrior thats easy to JET ?and where to get it? thanks
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
