piston & ring replacment on my warrior
Old Apr 6, 2004 | 12:27 AM
XJ4ME's Avatar
Default piston & ring replacment on my warrior
When i bought my 98' warrior it smoked a little and is progressivly getting worse. I can get a wiseco piston & rings for like 80$ off of ebay but how much of a pain is it to replace. I plan on taking the quad all apart to paint the frame so the motor will be out already. WIll i have to take just the top end apart or will i have to have the flywheel pulled and get to the bottom of the rod to this thanks
Old Apr 6, 2004 | 01:44 AM
phishnlabbat's Avatar
Replacing the piston and rings is quite simple. With a 4 stroke it requires a little bit more disassembly than a 2, and there is more parts to loose if your not well organized. If you've never done this before then I would highly reccomend buying a manual. Clymer makes a great illustrated book that breaks everything down step by step. Dont forget to get a new top-end gasket set when you purchase your new piston/rings.
Old Apr 6, 2004 | 08:33 PM
XJ4ME's Avatar
I assume this is the reason it is smoking?? its definatly blue smoke so it makes sense. Anyone know if you have to tear into the bottom end to do this ??
Old Apr 6, 2004 | 09:23 PM
No
Old Apr 6, 2004 | 09:33 PM
killerKXF's Avatar
if you have taken the bottom end apart you have gone to far
Old Apr 6, 2004 | 10:47 PM
macgiver's Avatar
its a piece of cake to do. i sent my jug to wiseco. they bored it, gave me piston, rings, gaskets and shipped it for i think 200 bucks.
Reactant
Mar 30, 2022 02:08 AM
southbayman
Jul 24, 2015 09:30 AM
Reactant
Jul 16, 2015 10:29 PM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
