Ya'll rode a Warrior w/ a HMF Pipe?
Awsome! but i can't really get the full effect the chain is so loose it slips on the sprockets when I give it a lot of gas or go up hill! But the thing is i can't get the bolts loosened to adjust the chain! I gotta taker in to the shop for that and to get it serviced!
To adjust the chain, you have to loosen the bottom axle carrier bolt(17MM on each side)....then, the tensioners, unloosin the nut holding the tensioner bolt in place on each side(12MM), then turn the tensioner bolt(10MM) in, on each side, make sure you have both sides equal.....if they are equal u will not be able to move them up or down but if u tighten of loosen one side the other side will be able to move up and down...so make sure there tight, tight the axle carrier bolt back up, and your good to go......just wanted to make sure that's what your doing.
mrtidy
02-03-2016 05:00 PM
