octane for a 4 stroke
Old Apr 11, 2004 | 12:44 PM
ENSTYLE's Avatar
Default octane for a 4 stroke
what is the octane of gas to run in a four stroke atv low mid or high to obtain the best performance
Old Apr 11, 2004 | 01:01 PM
Doctorturbo's Avatar
GOT BOOST!
That will depend on many, many things. If you have no mods, the best thing to do is follow the manufactures recommendations. If you have mods, the ones you have will dicate whether you need more octane.
Old Apr 11, 2004 | 02:54 PM
Ish416's Avatar
Doctorturbo is right.
I usually try to stay away from the cheaper stuff, tho it's not cheap anymore.
Old Apr 11, 2004 | 06:04 PM
Yamaha660R's Avatar
I think every quad should have nothing less then 93 pump in it. If you raise compression and have to run race gas that is a differnt story. But if you go pick up a quad at a dealership, I think you should always put 93 in it. I wouldn't run anything less in mine.
Old Apr 11, 2004 | 06:24 PM
thomez's Avatar
A stock Raptor would have more power with just 89, since it doesn't have the compression to need anything more. Remember, you want the lowest octane that does not pre-detonate. At that measly 9:1 ... 89 is fine. When you get up to 11:1 .. run 93 ... etc. There are a lot of factors.
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
