warrior troble
Old Apr 12, 2004 | 02:32 PM
warrrunner's Avatar
Default warrior troble
the is problem there is a tube coming out of the bottom of my carb that gose back to my swing arm and just stops when I turn my fuel on it comes pouring out does any body know where this is supposed to go?
I will try to put up a picture
Old Apr 12, 2004 | 02:39 PM
RoostItUp's Avatar
That tube hooks to the bottom of the carb and just keeps the fuel from draining on your engine and instead out the back and onto the ground. If it's leaking then I assume your float is stuck or there is a piece of dirt in there where it shouldn't be. Try tapping the bottom of the carb a few times with the end of a screw driver to knock the float loose. If that doesn't work you'll prolly have to take it out and clean it.
Old Apr 12, 2004 | 02:49 PM
warrrunner's Avatar
thanks man
Old Apr 12, 2004 | 07:19 PM
Boxhead's Avatar
I would agree, my friend had a warrior that had a piece of metal stuck in the float which caused it to do the same thing. The thing dumped fuel like hell because of it.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
