broken white bros pipe..
Old Apr 12, 2004 | 07:44 PM
WheelieKing's Avatar
Default broken white bros pipe..
my friends white bros e-series pipe broke at the welds were the pipe connects to the silencer. did this happen to ne one else? can he arc weld it back together??
Old Apr 12, 2004 | 08:32 PM
Old Apr 12, 2004 | 08:41 PM
Jarod's Avatar
if its steel, stainless or a few others then you can mig weld it, if its aluminium you could tig weld it, i did some welding on bigbearfx's wolverines silencer, seemed to turn out ok, but it was just stock, any ideas on what king of metal it is??
Old Apr 12, 2004 | 08:43 PM
AlphaRaptor660R's Avatar
Check out CaliRaptors pix...it happened to him.
Jarod's Avatar
really, i guess it would be best to just give it a shot, if you don't what else are you going to do with it??
Old Apr 12, 2004 | 08:45 PM
Jarod's Avatar
man, you beat me by less tahn 1 min.
Old Apr 12, 2004 | 09:00 PM
RoostItUp's Avatar
that happened to mine also, I just had a friend that was experienced with alum tig welding fix it. It worked great!
Old Apr 12, 2004 | 10:24 PM
alpharaptor, i looked at caliraptors pic page and thats exactly how my friends looked. the only experiance i have is arc welding and brazing. could you braze it? so its alluminum? you suggest he takes it to the same guy who welded his alluminum oil tank?..(he snaped the end of it trying to drain his oil)
Old Apr 12, 2004 | 10:33 PM
RoostItUp's Avatar
Anyone that has experience welding alum should be able to easily do it.
Old Apr 12, 2004 | 11:16 PM
alright man thanx alot.
Pehter
Oct 3, 2024 11:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
