Wolverine Specs needed
Old Apr 15, 2004 | 10:19 AM
weasel95's Avatar
Default Wolverine Specs needed
Can anyone provide me with the valve clearance specs for a 95 Wolvy. Also I have a manual for a old 350 Big Bear. Can I assume the procedure is the same for a Wolvy? Any other tips are welcome, as I have never adjusted my valves before. Thank You.
Old Apr 16, 2004 | 10:03 AM
weasel95's Avatar
PTT
Old Apr 16, 2004 | 11:10 AM
yamahawarriormods's Avatar
if the wolveriene has the same motor and specs as the warrior it is 0.06 to .10mm (.002 - .004inches)
exhaust .16 to .20mm (.006 - .008inches
good luck
Old Apr 16, 2004 | 11:15 AM
and yes i will probly be about the same procedure just make sure the piston is TDC on the intake stroke (top dead center) to make sure you have top dead center remove spark plug and use a flashlight or an allen wrench to see or feel were the piston is also if you can wiggle the rocker arms side to side then you now your on the intake stroke
Old Apr 16, 2004 | 11:54 AM
weasel95's Avatar
I'm confused. Dont I do the adjustment when both valves are closed, which would be the power stroke? On the intake stroke, the intake valve would be open.
Old Apr 16, 2004 | 05:33 PM
wolverine68's Avatar
The clearances previously given are correct. The engine should be cold and TDC on the COMPRESSION stroke.
Old Apr 16, 2004 | 06:10 PM
weasel95's Avatar
Thank you guys. Im meant compression.
Old Apr 16, 2004 | 10:46 PM
you do it at top dead center on the intake stroke the valve will not be open cause the motor is at the top i hope i'm not confusing you but this is how my manual describes it i had to do the same thing when i did my rebuild
suzuki230
Jul 8, 2016 10:03 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Mphillips
Jul 2, 2015 07:20 PM
ragewraps
May 27, 2015 08:07 AM
