Flat Tire?
Old Apr 15, 2004 | 02:49 PM
damandan26's Avatar
Default Flat Tire?
I just bought a brand new z400 and after 3 hours of riding I got a flat tire. The hole is in the side wall. When I pump up the tire I can hear the air coming out.
I heard that the side wall is really hard to fix. This is a brand new tire!!!!!!!! What should I do?
Buy a new tire or try to fix it.
Thanks for any suggestions
Old Apr 15, 2004 | 02:55 PM
GYTR's Avatar
Default Flat Tire?
i would stick a plug in it.
Old Apr 15, 2004 | 03:27 PM
caliraptor's Avatar
Default Flat Tire?
if the hole is small, just plug it...if its kinda big just take it to a competent tire shop and they should be able to fix it. You could also put a tube in it and forget about fixing it.
Old Apr 15, 2004 | 03:30 PM
damandan26's Avatar
Default Flat Tire?
I tried Slime... but it didn't work too well. It only allowed me to ride for about 2 minutes before the tire went flat again.
Old Apr 15, 2004 | 03:39 PM
caliraptor's Avatar
Default Flat Tire?
I dont think slime can really help the side wall.....just buy a plug kit and shove some in the hole [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 15, 2004 | 06:02 PM
MolokaiRider's Avatar
Default Flat Tire?
Plug it, put in industrial grade tire sealant (like the stuff used in forklifts). Works good, will stop nail punctures in main tread, does little for sidewall and adds some weight. (not good). The green "slime" coats inside of tire like the sealant I mentioned, but is harder to remove from the inside of tire when you want to put on a internal patch. The Indust/AG sealant is cream colored, cheaper, better...put it in ATV, both of my trucks, Farm equip...etc...
Old Apr 15, 2004 | 07:06 PM
soon2bBlaster's Avatar
Default Flat Tire?
my friends 450 R got a hole in the sidewall yesterday coincidence ?
Old Apr 16, 2004 | 12:34 AM
maha350's Avatar
Default Flat Tire?
dont use the slime. just go and get a plug kit. they are like $5 at walmart and they work. i had to plug a hole on my old 4 wheeler and it has been over a year and it hasnt leaked yet.
Old Apr 16, 2004 | 01:49 AM
UltimateAussie's Avatar
Default Flat Tire?
I would try to plug it if that doesnt work. put a tube in it. i get lots of use out of my tires. they get lots of nails and stuff punched through them. so i plug them up and then eventually put a tube in it. it is like getting a hole new tire.
2quiker
Mar 22, 2022 08:36 PM
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
caveeagle
Sep 19, 2015 01:20 PM
essonlaker
Sep 10, 2015 01:12 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
