how much of a horsepower gain going from stock raptor carbs to fcrs?
It probably wasn't the carbs fault that the rod broke. The additional power that the carbs gave the engine was the reason the rod broke.
You were pushing the rod to it's max capability, then you added carbs and it couldn't hold the extra power and let go.
Well atleast that's what it sounds like to me happened in your case.
#15
#17
I actually have enough money saved up to go with the fcrs now but i am thinking that the stock carbs jetted very high with mikuni mains might perform well also.Does anyone have a guess as to where start jetting at for sea level if and when i go with the 12.5:1 and a cam or should those changes effect the jetting that i have now much?I am currently using(175-180)mikuni mains which is pretty rich based on what others are using but it works for me.
