280 blaster or 13 yr old banshee?
Go with the Blaster, a 13 year old banshee could be problems, however you wouldn't have to worry about replacing brakes, suspension or pipe on the Blaster. Note a 280 Blaster will probably develop heating problems however. No one can make up your mind both are nice bikes, I just think newer is better.
Actually i will beg to differ, given the banshee has survived 13 years already says something for it, I would however be wary that failures such as ball joints and bearings could fail. I have a friend who has an 87 and after the Ball joints started failing he replaced the J arms with A arms and its just as good (actually better) as his 99 banshee.
With the blaster, thats quite a big bore and the engine will suffer greatly due to the High heat and lack of water cooling. The other thing is given that it is an expensive kit to build a 280 blaster it will be fairly hard and expensive for finding replacement parts for the 280 setup.
Just check the frames, axles, wheel bearings etc. and i suppose the rest is just up to a matter of opinion.
Jul 7, 2015 11:00 PM
