pistons and boring on a banshee
Old Apr 24, 2004 | 04:02 PM
lapeerbanshee's Avatar
Default pistons and boring on a banshee
i just got my banshee back today and i was told that i didnt have any idle screws and that i was getting dirt into my engine. so now i need new pistons and maybe even a crankshaft. so i was wondering what gets bored on the engine is it the cylinder or the piston that gets bored. i needed to know this because i dont know what size pistons i need to get because i found some but they all have different sizes and i dont know what size to get because im not sure if boring is on the cylinder or piston. and i dont know how to figure out what i need. all help would be appreciated
Old Apr 24, 2004 | 05:14 PM
JakalWarrior's Avatar
Here is what you do.... you take your cylinders to a shop and ask them to tell you what size pistons you need. Boring shouldnt cost more than 40 bucks per cylinder. They have to have the pistons before they bore it so after they tell you what to get then you go buy them and give it all to them when your done.
Old Apr 24, 2004 | 05:23 PM
ok but cant you buy pistons that are already bored
Old Apr 24, 2004 | 05:41 PM
you dont bore pistons, you bore cylinders till their clean then match em to the next closest piston size.
Old Apr 24, 2004 | 05:50 PM
ok you buy pistons that have the bore size of you cylinder and what size would you reccomend
Old Apr 24, 2004 | 06:55 PM
Dieselhead's Avatar
none of us can tell you that, thats why you take it to your machine shop for them to measure and decide what the next size will be, then you get that size of pistons to take to them so that they can fit the new pistons to the new bore size that they rebore the cylinders to.
Old Apr 24, 2004 | 06:57 PM
Nope. First they have to look at your cylinders and see how messed up they are. Then if its real bad and they're a good shop, they will bore till its clean and then tell you the nearest sized pistons to buy. Then they will match the bore to the pistons exactly. If its not real bad they will tell you what pistons to buy for the next useable overbore, then they get them and fit the bore to them. Pretty much you cant buy pistons before somone looks a the cylinders and tells you what to get.
Boring is like drilling out your cylinder liners so its clean and round, then your putting in bigger pistons to match the new size.
Boring will be between 60 and 80 for both cylinders, a piston set will cost about 150. Might as well get wiseco prolites or something similar since they dont really cost any more.
Old Apr 24, 2004 | 08:43 PM
ok thanks
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
