trying to jet my 98 warrior
Old Apr 30, 2004 | 03:26 AM
98warriorKY's Avatar
Default trying to jet my 98 warrior
ok let me see if i can explain this. i tried rejetting my warrior after i put a white bros. e-series exhaust on it but when i put the new jet on it falls through the hole into the carburator. i thought it was the wrong size cause the head of it is alot smaller then the stock jet. does anyone have any idea what i can do to fix it since i can't take the jet back now that i have used it? does anyone ave any pictures of there stock jet and aftermarket jet that i could look at to see if mine are the same?
Old Apr 30, 2004 | 09:43 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
there's many dif kinds of get sizes... i noticed there were in this catalog i got... they all looked dif not sure what i need... but u shouldlike maybe get a dif jet kit?
Old Apr 30, 2004 | 11:23 AM
yamahawarriormods's Avatar
the main jet is located inside the flout bowl at the bottom of your carb you will see it right there stock its a 145..... and easy way of doing all this is to just order a jet kit the show some good pics and tell you just how to do it...... also i would open up your air box when you rejet then you will notice a big diffrence from stock with the new pipe
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
