raptor sputtering
Old May 7, 2004 | 12:49 PM
  #21
wildwildweb16's Avatar
Default raptor sputtering
where are the idle screws at? are they just the mixture screws that you have to turn when you jet? i will put a new plug in and tell you what it is doing. i will have to go see if my dealer has a pilot. my luck they probably wont
Old May 7, 2004 | 05:22 PM
  #22
ok so i adjusted the float level. i put in a 25 pilot and it still ran like crap. went down to a 155-160, still ran like crap. I turn the choke on and it runs even worse. does that mean that i need to go even more lean? i tried to get the spark plug out but the plug puller keeps bending so i am having problems with that. also the backfiring quit. i think one of the boots on the carbs was loose
Old May 7, 2004 | 05:56 PM
  #23
anybody else have any ideas?
Old May 7, 2004 | 07:11 PM
  #24
caliraptor's Avatar
try 150/155....how many turns on the pilots?
Old May 7, 2004 | 08:24 PM
  #25
so i tried another little thing. i bumped it up to 165/170, went 2 1/2,2 3/4 turns and adjusted the float level again. put her back together and she ran awesome. took her down the block and back with no sputtering at any range. hope it is fixed for good. hope its not too rich. if it was too rich would i notice any sputtering or anything besides taking the plug out and looking at it?
Old May 7, 2004 | 08:40 PM
  #26
caliraptor's Avatar
My first suggestion was right. Check your plug after a couple of rides and a WOT plug check. If it was too rich you would notice BLACK smoke and it would bogg down if you blip the throttle too. Your best bet to checking jetting is the plug check.
Old May 7, 2004 | 08:42 PM
  #27
what is a WOT plug check
Old May 7, 2004 | 09:22 PM
  #28
caliraptor's Avatar
ItalianStalion told u how to do it....................."The best way to check your plug is to run a few miles on it first to get some color.Run the bike under a load for about a minute or so at 3/4 to full throttle then pull in the clutch, hit the kill switch but leave your throttle wide open all at the same time....coast to a stop and then check your plug."
I would run it at FULL throttle, just find a nice loooonnng straight road, street, trail and just try to get up to your max speed at Way Open Throttle (WOT) and kill it like he said.
Old May 8, 2004 | 01:00 PM
  #29
ok i will try that. it might be a little while tell i get to because i am heading out of town for a few days but i will let you know when i get back. Thanks for the help everyone
Old May 18, 2004 | 02:24 PM
  #30
I did the plug check and the plug looked good but when I was going up a low grade hill at about 3/4 to full throttle and then let off and starting shifting down, it died on me. Any ideas?
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
Bernhard
Sep 25, 2015 12:45 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
