Crank balancing for 686?
Old May 12, 2004 | 09:50 PM
1BADRAPTOR's Avatar
Default Crank balancing for 686?
it's a definite on the rod for your 01 farm, it's been on there for a while...
Old May 12, 2004 | 09:55 PM
FarmStud's Avatar
Everybody here been happy with there stage 2 cams? I'll probly put in +1 valves too.
Old May 12, 2004 | 11:01 PM
RoostItUp's Avatar
I'd save your money on the +1 valves I hear they don't do much unless you've got at least a 727. I switched my tranny over when I did my 686 also just for risks sake but then when I blew it the rod snapped the main axle and screwed the whole tranny up so that sucked my nuts. You might consider a better clutch, I hear sometimes they wear the stock ones out pretty fast.
Old May 12, 2004 | 11:07 PM
DollarBillz's Avatar
Originally posted by: Bigdaddy660R
When you want to make big HP on the top end, Truing your crank wheels to match your new rod is a very GOOD idea.......
very true
Old Sep 24, 2004 | 04:18 PM
  #15
MasterOfGoingFaster's Avatar
Actually, you balance the crank for both the Rod and Piston assembly, including the rings, piston pin, bearing and circlip. Everything that moves up and down. If you change pistons (big bore kit, etc) and the weight changes much, you should rebalance.
Disclaimer- I'm the webmaster at Falicon. But that doesn't mean I know anything...
Old Sep 25, 2004 | 06:55 PM
  #16
Ward660R's Avatar
I think that there are a couple better choice out there now (Craycraft's new one or the x-4), as far as a drag cam goes. For all around the stage 2 would be great.
Old Sep 25, 2004 | 07:11 PM
  #17
Outlawlawndragster's Avatar
MasterOfGoingFaster . isnt it true that on a single cyl they balance the crank by moving the vibration frequency out of normal RPM range
Or something to that effect ?
By the way did you say they allready have the 92mm crank for sale? What about a knife edge rod ? do they make one for the Raptors?
Old Sep 27, 2004 | 02:30 AM
  #18
FarmStud's Avatar
Glad I did, very little vibration and runs smooth, just need a little more grunt from the battery, evidently it takes quite a bit of juice to turn over 13.5:1 compression[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 28, 2004 | 01:22 PM
  #19
>> isnt it true that on a single cyl they balance the crank by moving the vibration frequency out of normal RPM range Or something to that effect ?
Yes. You have it correct.
Well..... We can stroke the Raptor to 92mm, but we use a standard rod, since we don't have a Knife Rod for it yet. We really don't advertise it yet, because the pro builders know we can do just about anything they want, and our web site is to help racers understand what is available to their engine builders. So, yeah, we can stroke it to 92, but we were waiting for more feedback before we started talking about it. You can order the crank and rod, but we don't have it as a kit yet.
The JE Pison catalog shows a 102mm piston. Get the 10.75:1 compresson, since the stroker crank will raise the compression about a point. The 92mm crank and 102mm piston will give you 752cc. That's a 13% increase in displacement, so you might need to think about a pipe, carb mods and perhaps valve work. Depending on your application, of course.
Plenty of folks run stroker cranks with stock heads to shift the torque curve lower..
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
